I have a chart with 3 groupings (user>week number>day) within that chart are 2 columns where the sum of the column is important at each grouping level (duration and bonus). The sums are used to show how many hours a user logged per week (duration) and the total dollar amount for a bonus where applicable. The new chart shows the sum at the lowest level (day) but not at the upper two which is a notable issue in funcitonality.
Am I missing a setting that needs to be updated or was this neglected in the new charts?
Hi @onlymatt - we recently made some updates here, as you noted, we might need to double-check this one.
Thanks
Hey @onlymatt our team pushed out a solution to this today, if you could try it again and let us know if it’s back to how it behaved before?
Yes! this seems to be correct again. Thanks so much
Actually, I checked another location and still see some missing items. This table should show the total for all groups at the bottom and when the group is collapsed it should still show the totals for each.
Sorry @onlymatt - we must have missed this somehow, we’re taking a look.
