Edit CSS style (Container)
It would be interesting to be able to add a Custom Code to the containers to modify the container style.
Or, if each container had a unique ID, it would be possible to modify the style from the Custom Code page. Thank you !
Hey @Thomas - thanks for the suggestion.
For what it’s worth, each container/section/component does have a unique ID/class which you can use to target them with CSS
That’s exactly it! It’s perfect, thank you!
