Filter: Allow multiple default values
In the Filters for users we can select “Allow multiple values” but we can only select one default value.
It would be nice if we could also select multiple default values.
Example usecase:
I have a list “projects” and I want to set my default status filter to “upcoming, running”
This way I see only those projects by default but if someone wants to see all projects with status “closed”, they could just select closed as filter and remove the other two. This way I can use one view instead of creating an extra view just for closed projects.
Yes! I think that this is the same request as this: Multiple values for default filtering
And this: Multi-Select Default Linked Records on Form
