How to create a form with editable text fields?
I want the user to be able to update their info beyond the default.
I tried to add a a button with the action: update a record → this record but it doesn’t add an input box?
Hi @DanEsd - it sounds like you’re trying to setup Action Buttons which certainly should create editable fields, unless the user doesn’t have permission to edit those fields (based on your Field Level Permissions
If you can leave a link to your app, we can double-check for you
