You can now set up any integer number field to be a rating field and choose from 1-10 stars. This means it will show up as a star rating field within your collections, record views and even within your filter fields as well.For those using Airtable: your rating fields will already have been synced and updated. For those on the Free plan, you might want to trigger a manual sync.
