Are there any work around to try and create similar layouts?
Options like this would be great.
Hey @rjp thanks for the interesting suggestions.
This sort of layout might be achievable with a combination of
- Containers (to setup 2 columns)
- Statistics with Gauge charts
- Charts with Pie / Gauge Charts
- Fields displayed in a details block with the display set to progress bar
It will definitely get you pretty close
i could get really close to the progress bar if i could get it to be 100% any trick to that i get about 75% when i select FULL
i can only get the progress bar to cover 75% even when i set to full? am i doing something wrong
or will it only go to 75%?
any ideas? im at a loss for what to do, as im taking up a lot of space to show little information.
I could get at the verey least twice the information in the same space
If you’re able to achieve the same thing with Custom CSS, I would recommend doing that.
You could also remove the labels, as it’s probably intuitive to your team that it’s start and end
If you want to send me a link to the page I can explore why it’s not filling the full width
