Parents and children in a hierarchy
Hello,
I have a task management use-case that requires a Ragged Hierarchy like the example below, where teams can belong to a department or also directly to the company, skipping a hierarchy level (in the real use case there are 5 levels).
Company
├── Department A
│ └── Team 1
│ └── Team 2
└── Department B
│ └── Team 3
└──── Team 4
Users can be requesters or supporters and can be assigned to any level of this hierarchy.
I modelled the ‘Hierarchy item’ table simply as a name and a parent field, because of the need of supporting a ragged hierarchy.
The task assignment works hierarchically. For example: If a supporter is assigned to Department A, he/she will only receive requests from Team 1 or 2.
So in order to know who can take over a task I have to check if the hierarchy item of the requester is a child of the hierarchy item of the supporter.
You can break this out in 2 topics:
  • Build the relation between parent-children in the ‘hierarchy item’ table: This is quite trivial to do in Coda or Glide with a filter formula, but have not managed to make it work in Noloco. I thought this could be solved with ‘Automatically link these records’ within the Parent field, but have not been able to make it work.
  • Get all children for a specific hierarchy item: Again trivial to achieve in Coda and harder but doable in Glide using a Javascript formula. Noloco formulas are more limited, so is the only option to use a workflow?
Thanks for your help!
Pablo
I tried to edit my post, because I think it was not clear what I was asking for, but I guess it’s too late for edits. So let me rephrase the last part.
What I want to achieve can be broken down in 2 topics:
  • Get the children of ‘hierarchy items’ using the ‘Parent’ field. I thought this could be solved with ‘Automatically link these records’ within the ‘Parent’ field, but have not been able to make it work.
  • Get all the children of children of ‘hierarchy items’, down to the lowest hierarchy level.
Can someone help me or point me in the right direction?
Thanks!
Pablo
Hi Pablo. I’m not 100% certain I understand your question, but I do something quite similar with my forms (form has questions, questions have options).
I only link one level up in my hierarchy; so option linked to a question, question linked to a form, form linked to a client etc. Keeps it nice and simple. Then I use look-ups to get the values from higher up in the hierarchy, because you can look-up from a look-up (if you get my drift!). That means from the linked record, I can add references to all the above hierarchies. Then can use roll-ups to get values if needed.
I’m not sure I’m explaining this well at all, but just think roll-ups and look-ups :wink:
EDIT - I see you also want to have different relationships, so Team sometimes in Department, sometimes in Company. So then you just need linked fields for both, and can select either/or. Then roll-ups for each. Then formula field to look at the roll-ups to see which has values. Again, probably not well explained, but certainly all doable.
