Problem with selecting the field type in the formulas
When working with formulas, I try to select the field type “Numbers (decimal)”, and the form breaks. This happens across the entire database.
When I try to select the field format “Number (Decimal)”, it automatically changes the field type to “Number” and the format to “Number (Integral)”.
Thanks for flagging this @MrZen - we’ll take a look!
Hey @MrZen - we fixed the underlying issue here, you should be able to correctly configure formulas the be number types again.
Sorry for the inconvenience this might have caused.
Thank you very much. I’ve already seen that everything in the table is correct now.
