Feature Request: Ability to hide title field in map view
- In the Map view for a collection, you currently are forced to configure a title field.
- This is frustrating because, when adding that same title field as an actual field in the “Options” configuration (so that it shows in the left-side list of records), you are then left with redundancy: the title field shows twice, once because of the collection’s “Title field” configuration, and a second time because of the field being turned on in the collection’s list of fields.
- This is a little confusing, but see the attached image for reference. The ideal solution is the ability to not have to set a “title field” for the collection, so that I can just rely on the field being toggled on under “Options” - that way it displays on the left-side menu.
e
