Advanced Themes
(1) Themes - Components
  • Ability to customize the style of each type of component - e.g., links, calendar, table, rows, etc. - and save custom themes. Alternatively, adding custom code box to the settings of each component would be nice.
  • Ability to define custom.light-mode and .dark-mode themes, as well as the primary and secondary style of each component type. This would allow for a diverse range of customization without interfering with the existing tailwind utility classes.
(2) Themes - Input Types
  • Ability to customize styles at the input level, or input type level (i.e.theming of all dropdown menus, each class of button, etc)
