Allow multiple automatic linking between multiple tables using a single shared field
We rely on automatic linking between multiple tables using a shared field (Survey ID) in our app. Previously, we could set up several automatic links from one table to others using the same Survey ID, but after the recent update, it only allows one automatic link per source field. This change has broken our workflow, as we need to automatically connect records across multiple tables whenever the Survey IDs match.
Please consider restoring the ability to set up multiple automatic links using the same source field, as this is critical for our data relationships and automation.
Hey @LegacyCreativeLLC
Thanks for the feedback, I agree it would be great to be able to support multiple automatic links on the same field.
Just to be clear, there’s been no recent behavior change here, the limitation of one automatic link per field has always existed, and it’s because we updated both parts when either change, which wouldn’t make as much sense if there were multiple involved.
I’m not sure if you’re mixing it up with something else that previously allowed multiple per table
