Needing the ability to append a record in workflows rather than completely overwriting the field. The update record function completely overwrites the field, but we need to just add to the field and not delete everything.
Hey @LegacyCreativeLLC - as you discussed with our support team, it should work like this already, you’re just running into an edge case we’re already looking to solve.
We should have a solution this week
Thanks! It’s already fixed and working now.
It sure is! Thanks for flagging it
