One thing that is easy to do in Noloco is to make a mess of your record detail templates.
You often need multiple views of the same data, which Noloco will create new layouts for; and you end up struggling to remember which is which. Typically this ends in;
Inconsistent experience for users
Difficult maintenance for developers
It would be fantastic to manage these away from the App itself, and be able to browse through each template; see listed which app pages are currently using them, merge, disable and delete them.
I’d also love to see that for forms too as they suffer from the same issues.
Thanks!
