Hi there, I am trying to build some mortgage calculators for my app but now realise I cant use a formula field in another formula (Can I?)
So, formulafield1 result + formulafield2 result =
As I cant do that, I thought I’d embed an external script but that doesn’t seem to work either. Is there an option to add code as below, it displays blank currently.
Hey Gary, I’m certainly no dev but have got scripts working in iframes with some help, so should work in theory. Looking at my scripts they all end with , not sure if that’s relevant?
And formula within formula doesn’t work as you say, be awesome if it did!
Thanks Luke, yes the preference would be to build my own calcs but not to be. Yet
Managed to get the external working by using the url only without the script.
Cheers
