It would be cool if you could put the comments on the bottom of a record page. The use case would then make it more like a slack/missive/other collaboration tools, with comments on the bottom instead of the side.
Can you explain what you mean by “bottom” ?
You can add the comments to the main body of the page
(quietly hides away into a hole)…
WHOOPS
Feature request solved!
