Currency appearing in fields
Hello, this morning I changed the default values of 4 fields to £0 before changing my mind and removing the default value to blank.
However I cant seem to remove that value now, I have saved/published the app, cleared cache, closed and openend incongnito but nothing seems to work.
Anyone have an idea how I could remove this. It seems to have stored that value, if I change default to 10 that then stays even when removing. Its a new record so the db has no set value at this point, in fact no record at all.
Not sure if this a small bug, I have found a way to remove but feel its unnecessary and wasn’t needed prior to adding the default.
Thanks for flagging @garyGHL - if you run into this again I think you can remove the field from the layout and re-add it, effectively resetting the settings
