Custom color scheme for charts
Hello, does anyone know if its possible to create a custom colour for charts or even edit one of the pre-defined colours? Id like to change the standard red to my brand colour. I could set this by changing the overall colour scheme of the app but I want to retain the dark grey on that.
Thank you
Hey Gary,
I don’t think so. As a workaround, you could design the charts with graphy.app and embed them in Noloco with an iFrame component.
Graphy.app is only $16/mo and highly capable of producing the aesthetic you’re after in very little time…pretty turn key tbh.
I ran into a similar issue when trying to use Noloco’s native charts and have since been using Graphy to create and embed the charts in Noloco. The charts can connect to your database and remain dynamic as well.
Best,
Thank you, I’ll keep that in mind going forward, it looks nice.
Is it possible to connect Airtable to the database for Graphy.app?
Thks
Yes I’m sure Graphy can connect to Airtable. I connected Supabase to Graphy through the api and it was pretty straightforward.
