More custom design options for graphs (editable)
Hi Noloco users!
It would be great if it was possible to custom edit charts in a more granular way, example:
Displaying one series as an area or barchart and the another as a line (dotted etc) to be able to compare values in a more pedagogical way to customers. Lets say you have a project cost value and want to compare it over time wit a limit or goal value:
Today if you have multiple series in noloco they are the same type: barchart, line, etc.
It would also be great to be able to customize text size and layout of graphs in a more granular way: text size, colors etc, similar to quickcharts.io (chart.js).
I understand if this perhaps can become an cluttered UX for Noloco, so perhaps one solution would be to get access to a more advanced code editor for the graphs?
Upvote this post if you also think it is an important feature for your work with Noloco <3
/Alex
Pinging this thread and wondering if there is any interest from the community? And if Noloco has any plans on creating a more customisable chart builder in Noloco?
Best,
Alex
You can do this by adding multiple charts in the same block, no?
Do you meaning have two charts next to each other? Or do you mean adding multiple series within the same chart?
In the chart above I have two different series in the same chart:
Series 1 - Line chart
Series 2 - Dotted line chart
Yes, 2 charts next to each other. That’s the only option for now.
