Customize button text and hide buttons within modals
What
  • The ability customize the “cancel” and “confirm” button text in an action button modal, as well as the ability to hide the button(s) entirely.
Why
  • For my example, see the screenshot below. In this use-case, the action button triggers a modal for a client to book a meeting. The language “confirm” is a little confusing because the actual act of booking the meeting occurs entirely inside of the embed. So in this example, I would retitle that button to “Close” or “Minimize” and would probably hide the cancel button since that wouldn’t do or mean anything.
  • Another example includes an action button titled “Instructions” that triggers a modal with a video tutorial or something. Being able to just click a “Close” button would be nice.
Exhibit
Agreed - I’ve ran into a similar issue when embedding a Fillout form.
I know, I know…noloco forms > fillout forms, but sometimes it just doesn’t cover the robustness I am looking for, such as loading existing record data at the launch of the form and doing calculations while the user is actively working on the form.
100%!! You should put in a feature request for those things. Loading records and running calculations would take Noloco forms another level up.
I often use embedded forms from Cognito which are quite robust in capturing data. I often show these forms using the Iframe modal, but users get confuse with which buttons to press, often clicking on the Confirm button shown in the modal.
So my use case is the ability to hide/show buttons, and definitely also the ability to change the text on both buttons (cancel, confirm).
+1 to both these requests; ability to change button text on form modal, and ability to hide the button altogether (when launching iFrames)
This has now become one of my top feature requests. Clients have expressed how weird they find it that the button says “Confirm” one says “Cancel” and then there’s the little X icon to close it out as well, when some or all of those buttons may be irrelevant depending on the purpose of the modal.
Once again the “Confirm” button has tripped up my clients :sweat_smile:
Depending on your use-case for a Noloco modal (like viewing a document), “Confirm” is misleading and confuses endusers.
Would really benefit from a tweak that allows us to customize the “Confirm” button’s text.
Yes please! I literally just had to change the way I had my calendar scheduling embed due to the same reason. My clients all claimed that tried to schedule a meeting and never received any confirmation-- all because of that Confirm button and the modal cutting off the bottom of the embed with the actual button to confirm.
Bumping this once again. This post is continually top-of-mind. We really need to be able to simply customize the button text :sweat_smile:
Yes - I ran into this again just today. Here to help you bump again :slight_smile:
+1 - This seems like an easy fix and would improve the UX a lot!
Upvote! I’ve has some user feedback that this would solve.
Bumping this once again. After more than a year, I’d love to see if this can be prioritized. It’s a pretty simple update (in terms of scope, though under the hood maybe it’s challenging) but would be a big qualify of life win. This is a very strange UI/UX thing.
And it strikes again! A client has brought this up yet another time. We really need the ability to just turn off these buttons at the bottom for informational pop-ups. They’re useless (for this use-case) and confusing to users.
+1 to this, would be really usefull
You can at least change the text now I noticed! So at worst you could just make the button “Close” - although my not work in your context. But it’s progress at least!
Thank you for calling this out! It is indeed at least something.
