Decode Product data from a Barcode?
Hey all- I’m brand new to trying anything with Barcodes. Love the built-in scanning feature with Noloco.
Is there any way natively or through integrations (make or zapier) to decode the data from the Barcode or from the barcode number after it is scanned?
What I’m wanting to do is be able to scan a barcode and essentially update a status of a product, but the user won’t have the barcode initially (until it arrives at their home) so it’s not like inventory tracking where you have the barcode number first, then scan a barcode number- find the matching number to update that record.
So I’m wondering if I’m mis-assumed the focus of the barcode feature? Any thoughts are appreciated!
