What's new in Noloco: AI Formula Help, Search by Barcodes and more
Hey everyone :waving_hand: It’s been a minute since our last update, so we have a lot to share.
Scan a Barcode & Open the Record
You can now scan a barcode and open the associated record, with our new navigation action button on any of your tables! With this feature, you can instantly lookup a record by scanning its unique barcode. If a match is found, you’re taken directly to the record page—no more manual searches or delays. It’s perfect for boosting efficiency in workflows like inventory management, order fulfillment, and asset tracking.
  • Inventory Management: Pull up product details instantly.
  • Order Lookup: Locate customer orders by scanning barcodes.
  • Asset Management: Access asset records on the fly.
barcde-scan-navigate
Loom & Vimeo Support
You can now seamlessly showcase more videos in Noloco with the addition of Loom and Vimeo support! Whether you’re building an E-Learning Portal, Onboarding Platform, or showcasing product features, embedding Loom and Vimeo videos into your Noloco app is easier than ever.
  • Loom: Easily create and embed product tours or walkthroughs directly into your Noloco app. Share insights and guide users with a few clicks.
  • Vimeo: Host your video content on Vimeo and embed it effortlessly by simply copying and pasting the Vimeo URL into your Noloco app.
Filter by Empty Value
Spotting gaps in your data is now effortless with our new “Filter by Empty Value” feature.
Whether you’re looking for missing email addresses, unassigned tasks or incomplete orders this feature simplifies the entire process, keeping your data clean and manageable.
  • Find empty fields effortlessly: Simply apply a filter to your dataset and locate missing data instantly.
  • Focus on what matters: By managing your data, you can focus on tasks that require your attention without wasting time looking for missing data.
  • Keep your data clean: Streamlining your data and fixing incomplete entries ensures your workflows run smoothly.
filter-by-none-xl-30fps
AI Formula Recommendation
Creating complex formulas in Noloco has never been easier.
Now you can simply describe the formula you want to create or explain the change you’d like to make to an existing formula, and our AI Assistant will generate the ideal formula for you—quickly, accurately, and with zero guesswork.
  • Describe your formula needs: Whether you need a formula from scratch or just want to tweak an existing one, simply type out what you’re aiming to achieve.
  • Get instant results: Our AI will take your description and deliver the precise formula you need, every time.
Other improvements
As always, there’s a host of other updates that we need to mention too
  • Huge update to how you create and edit Noloco fields
  • Support for Xano UUID primary keys
  • Control the width of the iframe in an iframe action button
  • When you duplicate a tab, the components get duplicated too
  • Support SMS links and other link protocols in navigation buttons
  • Added lots more Videos and Guides in the platform
  • Support for ordering your fields in the data tables
  • You can now transfer an app to another paid workspace
That’s all for this update! As always, let us know what you think about the new features, and if you want to request a feature checkout our feature requests
Darragh & the Noloco Team
Is the barcode feature still restricted to higher priced plans?
Great question @Tobias - at the moment yes it is
Thank you for clarifying
Any plans to be able to create barcodes or QR codes?
Hey @rjp - we do plan on supporting this!
It would be great to understand what you’re hoping to use it for, simply converting URLs and text to QR codes?
we would like to have a tool tracking portal. if we could take the unique id of a tool and create a qr code we could print then place on tool so when scanned it would take you to the record and you could check a tool in or out.
We would also create training docs and forms that would have QR’s. that way you could scan a qr and it would bring up the training manual or a form/survey.
Thanks for that great context @rjp
