Quick Tip: Noloco MySQL Join Tables Need Three Columns
I recently discovered something helpful when setting up join tables in my Noloco MySQL implementation that wasn’t immediately obvious to me.
The Issue & Solution
My join table with just two foreign key columns wasn’t being recognized properly by Noloco. After contacting support, I learned that join tables should have three columns: an ID column plus the two foreign keys.
Once I added the primary key ID column, everything worked perfectly!
Important Note About Reserved Names
Remember that Noloco has reserved field names including id, createdAt, updatedAt, and uuid. When you add an id column to your join table, Noloco will rename it to “[Table Name] Id” in the interface, but this renaming doesn’t affect functionality.
