Issues/comment on new UI style updates
Loving the new style updates, particularly the new button styles, thank you!
But feels like the “notices” element might need a just a tad more attention:
  • There is now very little definition between the title and sub-title, they look almost identical
  • The “hide subtitle” switch doesn’t work so end up with the text vertically mis-aligned in the banner when there is a button (bit like it was before you added that “hide” switch”!)
  • The grey default is perhaps a little too similar to the background colour now the outline has been thinned right out, makes it easy to miss
  • The yellow version looks a bit washed out and hard to read
Not a “bug” as such, and some of this subjective, but wasn’t sure where else to put it!
But there is one small bug; when using Split View with a button, there seems to be a hover point, right at the top of the button, whereby the tool-tip is shown at the very top-left hand-side of the screen.
