Feature Request: Limit to one “Field is required” notice in forms
- I guess this is more of a change, a reduction even, rather than a feature request.
- See the screenshot below. After deselecting an option in a field that is required, the “[Field] is required” notice displays under every choice in the field.
- From a design standpoint, it feels a bit overkill when looking at it. Additionally, its more intuitive to have one notice since the point is that the FIELD requires an entry, not that each option has to be ticked.
- Perhaps one notice above all the options or one notice below all the options would be a good solution.
a
