It is possible to fill "required" fields only with spaces and still submit the form
It is currently possible to Submit forms with text fields that are only filled with spaces despite being flagged as mandatory to fill in. I have tried to use a regex expression to avoid that but it will not prevent the user from submitting the form. Also tried to limit the amount of characters via regex to 100 I was able to submit over 100 characters in a text field in a form. I used the following expression:
^(?!\s)(?!.\s$)(?!\s$).{1,100}$
Same behaviour when updating a text field later in the record view.
Seperating the restrictions into seperate rules helped. Also simplified the regex to [1].+[^\s]$ and it works.
  1. ^\s ↩︎
