I’ve just started testing a new app as an actual user. I have a split view with a create button. When the user creates a new record, sometimes it shows immediately, sometimes not (which is very confusing for the user!). I know this somehow has to be related to permissions, as it doesn’t happen when I’m an admin.
Note I’ve tried all sorts to change the permissions set-up, even adding the user to the record as a hidden field, then using that for permissions, but same issue.
Any tips for getting this to work?!
@darragh this could be related to the Xano issue as its the table that uses UUID rather than ID.
Hey @lukebranford
Depending on how many records you’re loading, it could be just the delay in remaking the request for the list after you come back to that page.
If you want to link us to the page and the permissions we can certainly investigate if there’s anything else happening
Thanks for getting back to me @darragh. It’s only a small amount of records getting loaded, so not sure it’s that. I will ping via the support channel. Thanks again
