Noloco Changelog · October 19–25, 2026
This week, we’re introducing MCP connections for Noloco, making it possible to work with your app’s data through AI assistants like Claude. We’ve also improved tables, grouping, page navigation, and app configuration with Nola.
Connect your Noloco app to your AI assistant
You can now connect your Noloco app to Claude and other compatible AI assistants using MCP, letting you work with your app’s data through conversation.
Find records, ask questions about your data, and, with the appropriate access, create or update records without switching back to your app.
To get started, open Profile menu → Connect your AI. Select Add to Claude, or copy the connection URL into another MCP-compatible assistant.
You stay in control of access:
  • App admins choose which roles can connect, with No access, Read only, or Read & write permissions.
  • Assistants act as the connected app user and respect that user’s data permissions.
  • Users can review and revoke their connections from the same menu.
Refreshed tables with more control over your view
The redesigned table experience is now broadly available, with updated styling, cleaner grouping, and better inline editing.
Builders can adjust table width, style, and row height from the view’s layout settings. Grouped tables have a clearer presentation, with headers adapted to contained and full-width layouts.
When inline editing is enabled, supported fields can be updated directly in the table without opening individual records. Column-pinning controls also help admins keep important fields visible while scrolling horizontally.
Organize Cards and Columns with up to three grouping levels
Cards and Columns layouts now support up to three levels of grouping, making it easier to organize records into meaningful categories.
For example, you can group records by region, then team, and then status, all within the same view. Set up your groups in the view’s grouping settings or ask Nola to configure them for you.
A more consistent page and block experience
We’ve refreshed page headers and blocks with more consistent spacing, framing, and header controls across your apps.
Scrolling behavior has also been improved to keep navigation and tabs accessible as larger page headers scroll out of view. Header action buttons stay beside the title when space allows.
More flexible visibility rules with Nola
We improved how Nola configures button and section visibility rules using roles, the logged-in user, and fields accessed through relationships.
This makes it easier to create controls that appear only for the right users or records, with more reliable validation of the rules being configured.
Smarter hidden form values with Nola
We improved how Nola configures hidden relationship fields, allowing them to be populated using related records associated with the logged-in user.
For example, a new request can automatically link to the user’s associated client or organization, making forms easier to configure for your data model.
A cleaner builder settings sidebar
We refined the builder settings sidebar with clearer labels, simpler borders, and more useful default section states. Relevant sections open by default, while others stay collapsed to make settings easier to scan.
Your expanded and collapsed preferences are also preserved, so the sidebar stays organized the way you prefer.
Clearer filter configuration guidance
We improved filter validation to help builders identify when a role doesn’t have permission to read a field used in a filter.
This makes it easier to understand why a filter may not behave as expected and configure the right permissions.
Thanks for all the feedback and feature requests.
We’ll be back next week with another round of updates :rocket:
