Problem when setting-up filter (date)
I am looking to filter records to only show dates after today (now). I am able to make the filter work but it will not show on the right side panel of the menu editor as a filter criteria. Instead the filter field stays empty as if there was no filter criteria behind. Therefore I cannot add any additional filter criteria (workaround is to create other before).
See the screenshot below.
Hi @JCW could you reach out to our support team with these details - it looks like a rendering bug with the filter “preview” for multi fields.
That said, is there any way you could change the lookup value to only have one value instead of being a multiple value?
Thank you for your quick feedback Darragh! With one date field as a data source it works fine. I won’t need to use the lookup function with several dates therefore for my current use case I am fine.
