Single Select Color Configuration Not Persisting in MySQL Integration
Issue Description
When configuring colors for MySQL ENUM fields in single select components, the system:
  1. Initially shows all possible ENUM options during configuration
  2. Fails to save color configurations consistently
  3. Sometimes loses options beyond those currently in use
  4. Assigns random colors to new instances instead of using configured colors
Environment
  • Database: MySQL
  • Field Type: ENUM (used for status and state fields)
  • Application: Production Management System for order/task tracking
Impact
Unable to maintain consistent color-coding for status and state fields, making visual tracking difficult and configuration time-consuming.
