Summarized Columns
A newbie question. I need a Value for an NPS score per month. So I need to filter on a mont then the total of respondents needed to be count, the total of promotors and the total of detractors. In Noloco I need the feature Colum Summary for that I guess. However: no way I can find this. This article doesn’t help either: Column Summaries | Noloco
Hi Turlings!
For the grouping, I’d recommend using in-line filters above the table, or even better, grouping the table by an auto-computed “month” field.
For column summary, open the table settings, go to fields, open the configuration for the field, and you should see a summary option.
