I’m currently documenting how my app works, focusing on all the workflows, what they do, and how/where they are triggered. Haven’t done this in the past and really regretted it!
A very time consuming and boring task though, would be awesome if could use AI to get an automated technical report from Noloco
This would be awesome, if it could also produce a diagram showing the tables and their relationships to each other too would be epic.
Yesssss if only!! This would be a dream!
Look into using Loom premium it’s a life saver for this… When im done working on a particular set of functionality I fire up loom and talk through every step while it’s fresh in my mind.
Loom will take the transcript and allow you to generate SOP’s / Documentation and having the video is very useful. I’m not 100% sure but it seems that it uses some screenshots of the video to inform the SOP’s because it will catch details from the page that I don’t talk about explicitly.
I store my documentation in Remnote for easy search ability.
https://scribehow.com is another tool I hear is good for this, but i haven’t tried it yet.
Awesome, some great ideas, will check it out! Thank you
