Right now, a highlight element (or even a detail element for that matter) can be configured to just one linked field. This is sufficient for most use-cases, but sometimes I’ve really wanted to display values from the main table AND from a different table (through a linked field) within the same highlight element.
This configuration is what I’m referring to:
To be clear, I 100% see the value of being able to anchor the entire highlights element in one record. But it would be nice to be able to let some of the elements in the highlight be from a different linked record. That would also allow builders to bypass having to create extra lookups and/or rollups to achieve the same thing.
