Hi everyone,
I see there’s an intro section so figured it couldn’t hurt to post.
I’ve been working on creating a system for storing GPT outputs for the past few months. Something like: capture outputs, capture prompts, capture custom GPT configs, and combine them in a UI that provides a mix of knowledge base and CRM capabilities.
It’s been a huge struggle to find a low code tool that could handle the many relationships in the database intuitively and Noloco has impressed me far more than any other tool I’ve tried to date. I’ve started building one by hand but … frontend design is a lot harder than I was expecting (I think I’ve accepted that it’s just not my jam).
My adoption of Noloco has been sped up by simultaneously needing to build an internal tool at very short notice for an event that I’ve been coopted to help manage as part of my job.
What started as a few simple asks from colleagues quickly spiralled into a massive administrative headache for me and my colleagues (while wonderful but many of them less technical) were not adopting Airtable despite my fervent pleas.
I went looking for a frontend builder and found the majority of tools too limited or difficult to use.
Noloco is the only solution that I’ve found which strikes the balance between being easy to use and also powerful under the hood.
My Airtable has elements for recording media at the event, guests, and newsletter opt ins. A lot of moving parts. By building a good UI, I’m slowing getting on top of joining up all the dots.
Great tool and might drop in with the odd feature request as those pop up during use.
