Workflow conditions IF + ELSE
Hello,
I created a button to generate a PDF.
Depending on the conditions, this generates a different PDF.
So I have 4 different documents.
So I created 4 workflows (one for each document) with an IF condition for each workflow.
However, this message is displayed ( Note: other workflows will not run as a result of this action. When this workflow action is run, it will not trigger any other workflows to run.) and obviously only the first workflow is started.
It would be very relevant to develop the IF/ELSE conditions to launch the correct document with only one workflow.
Thanks !
Love this idea. We have many use cases for this as well!
