Hi,
Am a newbie with Noloco and am creating a portal for a customer. I want to be able to give Admins the option to change settings for the users - e.g. change a users role or to give a user specific functionality.
Is there a way to do this using checkboxes or slide switches per user?
Thanks
Steve
Hey Steve
This is usually done by changing the user’s role
Any admin can change any other user’s role
Here’s a quick guide on how User Roles and Permissions work in Noloco:
Hi Darragh,
Thanks for the quick response. Let me give you a scenario to make sure that my thinking is sound when using the roles.
I am working on an app that tracks student’s late arrival at school but they are some students that are given a little leeway for various reasons.
So the majority of students need to be there by 8:30 (role Group A) after which they have to report late. Some students however have activities offsite in the morning and are allowed to get to school up to 8:45 (role Group B).
So, I assume that using the roles, if a student who was previously expected by 8:30 now takes up a morning activity, their role would just be changed from Group A to Group B.
Assuming that I am correct, can the Admin then just have a button that will make the change for the student rather having to edit the database directly?
Also, is there anyway to perform login checks in Noloco? I read a post that shows how to do calculations, so I figure that I should be able to store the # of minutes late subtracting the expected time from the actual arrival and storing that result.
Would I then be able to perform logic checks when displaying a chart so if a student is less than 10 minutes late, it will show in one colour, if between 10 and 20 another colour and over 20 another colour?
Thanks
Steve
There’s a few things to digest here @SynopsisLabs but let me try
Yes that could be one way to do it.
This might not need to be a role though - it could be an attribute of the student such as a category or status.
Absolutely, this would be a great use-case for a dedicated Action Button
This sounds like you could use a formula field to do the calculation
Then you could put that on a chart, it would probably be best to use another formula based on that time result, to categorize them, which you could chart/color
Thanks very much for the response. Will give it a whirl!!
