Attachments wont Sync to Airtable
We are having a super super frustrating Bug in our customers Setup.
The whole app is based on uploading documents or photos of documents.
First of all there is no option to upload more than 1 attachment at a time which is already frustrating but we can live with that. Second not all attachments get synced to Airtable.
Its either all of them, or only one, or the second one overrides the first one and so on.
This makes the whole thing pretty much unusable and for 150$ license per month you wish for some more consistency.
Het @mosesg - you should be able to select multiple attachments in the file picker, instead of choosing one and then choosing another.
If however, you often need to upload multiple files, you can do so with an action button, which will only start the upload when you “submit”
I’m not 100% how this would be happening, but if this is something you’re running into, I’d also reccomend using an action button that “submits” just once.
