It would be a time saver if we could copy filters. For example, here I have to change eight field settings to “enable editing inline” and “only be editable when conditions are met” manually having to add all the filters even though they are all the same configuration
Second that - and since some filters (especially with [OR] arguments) can get complicated fast - a single change to a complicated filter might mean a lot of steps.
@darragh probably a power-user feature, but it we had an option to “edit as JSON”, and be able to tweak a filter that way, AND therefore also copy/paste, that would be incredible. Apart from the need to add error-handling to this sort of interface, it might be an easier implementation than the “copy filter” function we’ve all hoped for.
