CSS for the addition of colored tags onto data
We need help to write up custom CSS for the addition of colored tags onto data in Noloco. There’s next to no documentation on it from Noloco, which means it’s quite challenging to target the right components/classes.
Here’s the use case: the user is assigned a role by admin > if the appropriate role, they see the exclusive data, if not, they will see a colored tag with redirect to a pop-up form where they can request access.
Thanks.
Hi,
I have worked extensively with Noloco’s styling system and can help with your custom CSS implementation.
Would be happy to help set up both the conditional styling and the popup form integration.
Let me know if you would like to discuss further details about the implementation approach.
You can reach out to me on my email here
Colin
