I did a simple CSV data import, like I do every month. Total records were 124. Only 60 lines imported. Also, I did not get the “Your import has finished successfully” email either. There is nothing unusual with the 61st record that would have caused a fatal error. Since I didn’t receive any kind of confirmation email, I am hesitant to import the remaining 64 records because of potential duplication. Is there a log for imports that can be reviewed?
Hi @sreynolds - sorry you had some trouble importing records
If there was an error you should have received the report via email
If not, typically it finishes, unless something else went wrong on our side.
In this situation we would probably advise deleting the ones that were imported and starting again, or identifying which were imported and not re-importing them (to prevent duplicates)
