Duration field is displaying seconds
I have an Airtable field set as a “Duration” type, displaying only hh:mm. However, in Noloco, it displays as hh:mm:ss, with no option to control or customise the display format.
Hey @Kieran you now have the ability to control the format of your duration fields, you can choose between hours and minutes, or minutes and seconds
I forgot to reply as I was so excited I got building straight away, amazing thanks @darragh this worked perfectly.
