Error when exporting to CSV integer
I have a problem, I have a table with a number that some start with 0 and the field is in the Text format, when I export to CSV this column is as an integer, excluding the zero on the left, has anyone experienced this?
Are you opening it in excel? I know excel/sheets will auto-format sometimes
