Hi All,
Not sure if this is a bug or if I’m doing something wrong, I’ve got a table which has predicted payments & actual payments and I’m trying to display this on a line chart with 2 series’ based on the record’s “type” field (which determines if predicted or actual).
When I initially create the series I can see the records in the chart, but the moment I filter it by the “type” field the records disappear off the chart.
The data is definitely there and matches the filter so not quite sure what is going on?
