How to create a new Color rule linked to specific value in a project?
Hi,
Great with the new color rule that came out!
However im not really getting it to work as I want:
I find the value i want to color red but cant find project values for the operator to compare against (smaller or bigger than X)
So far so good
But here I cant find any values from the project it self?
Heres a quick loom where i show the issue:
Ok solved!
Not in the way i wanted to above but by creating a new cell C which took A minus B and then i just set it if <0 then Red if >0 then Green. :slight_smile:
