Hubspot deal pipeline set-up & couple of small issues
Not really a “bug” as such but wasn’t sure where to report.
Been playing with HS integration, really great work!
But the deal pipeline comes in as a separate table, which is good, but makes setting up a sales kanban board a bit tricky:
  1. Can only order A-Z/Z-A in kanban, so had to rename my pipeline stages with numbers - OK for me but might cause issues for others
  2. Because linked field, there is no way to show columns with no current deals in them, which is a bit of an issue for me! Perhaps an option to show empty?
Also, I’ve noticed:
  1. In Make webhook, you get very little details about the HS record in the webhook response
  2. When I added Notes, companies and contacts were named the wrong way round somehow
Apart from that, all very cool :sunglasses:
Thanks for the feedback @lukebranford
We agree with pretty much everything you’ve said.
Trying to Fit the hubspot model into our typical table model came with some trade-offs, the main one being around pipelines stages, which are neither single-option fields, nor linked fields…
We’ll definitely take this into account though and see what we can do as the integration evolves!
Can you expand on this part a bit? I’m not so sure what you mean
@darragh let me dig out that notes issues and I’ll report back.
Another issue I’m facing now; I can’t seem to move deals in the pipeline.
If I try to drag, nothing happens. If I try to do via form I get:
Something went wrong submitting the form
Pipeline Stage must contain a valid stage for the selected pipeline
Note that the Pipeline Stages look OK, and all associated to the Pipeline.
But in the Pipeline table, only some of the stages are listed as linked fields.
Also I’ve noticed in the UUID for the stages, some of them have valid looking UUIDs (numbers) but some of them are text, not sure why, these look like they could be old out-the-box stages perhaps?
https://portal.recordr.video/_/data/internal/hubSpotPipelineStage?lt=data
@darragh Any advice on how I can get changes to deal stages working?
I can deal with the empty stages etc, it’s more how I can’t currently change the pipeline stage, even via a form. Thanks :slight_smile:
If you can send us a link to the page we can check what’s happening @lukebranford
Thank you! Here is the page:
You’ll see you can’t drag a recordr (please feel free to test). And if you click into a record and use the Update button and try and change Pipeline Stage, you’ll see it throws error. Have tried figuring it out myself but no joy!
Is that the right link? That’s a link to the data tab - not a kanban board?
Apologies: https://portal.recordr.video/sales-admin/deals
Did you have any joy with this Darragh? Thanks!
Hey @lukebranford
We’ve rolled out some changes this afternoon to address issues updating pipeline stages for deals.
This should fix the issues with the validation of pipeline stages you were seeing from the form, as well as drag & drop updates for kanban.
Let us know if you continue to see issues with this.
Hi Niall, that’s great, thank you, just tested and all working nicely, good work!
And very small issue, but maybe not so quick to sort your end; some of the Hubspot fields, which get pulled across when the tables are synced, are not mapped to the correct Noloco field types. Most of them are just decimals where they should be Integers, so it’s only really a display issue (e.g. Deals - daysToClose), but some are text string where they should be something else I believe e.g. Deal - hsV2TimeInCurrentStage - should be a date. I fully appreciate that there seems to be 1000s of HS fields, so mapping them all correctly is a time-consuming headache, but just thought it worth flagging!
