Now it only seems to find text/number fields in the table, not sure how to work around this.
If you don’t want to use the filter field for the single select you could also have a function that displays the text of the single select. Not sure if this would fit your use case but I have several setups like this where I need to reference the name of a select field.
Yea i did this too, but would be neat if the searchbox also searches for text in the single select fields, lets say for companies or product categories instead of only being able to search for product name now
I agree, searching all fields seems ideal but I could also imagine situations where that would be unhelpful. Most ideal would be choosing which fields the search applies to on the backend.
