Link/unlink questions
Is it possible to change the name of the link/unlink button when it is only doing the link part?
When I’m also adding a record, that’s fine, I can change
Creating a new record using the Link/Unlink button
It is possible to create a record from a link/unlink button and be linked automatically.
To make it clear: I’m creating text to insert into a project, for example. I’m using the link/unlink + create a record button to do this. So I want this text linked to this specific project. But instead, when I’m done editing, I still need to link the newly created text.
Great question @AcervoVivo
This is something that’s been asked a few times, and is certainly something we want to implement
It sounds like you should enable ‘Create a new record’ that should automatically link it
This guide explains that in more detail:
Thank you for givem me the ability to change the name of Link/Unlink button!!
I almost had an heart attack because they all desapeared :crazy_face:. But then I toggled then again e saw the new feature (for me it was new :smiley:)
Very glad you like it!
Enjoy customizing all the buttons
