I have a table called Tasks with a self-linked field “Subtasks”, I also have a rollup field in Airtable to rollup some data from the subtasks, but I have just noticed that this isn’t updating correctly.
Upon further inspection it looks as though Noloco is keeping track of the Subtasks inside it’s database but is not syncing it back into Airtable.
A couple screenshots for example:
Record 1370 has 3 subtasks:
The same record in Airtable shows no subtasks:
Other linked record fields to other tables are working fine, it appears to just be the self-linked fields that aren’t syncing across. Linking them in Airtable seems to sync to Noloco too, it’s just when linking in Noloco it doesn’t sync in Airtable.
