Some of my linked records are not displaying correctly. The info is in airtable but not in noloco. I’ve had this issue in the past and solved it via manual sync but it doesn’t seem to help now. All the user collection fields should be filled in this image.
Hi @onlymatt if you can DM us a link to the table, if it’s still an issue we can investigate this for you.
Given this is a linked field, you might need to run a manual sync on the linked table rather than this table to fix the issue
Syncing from the linked table seems to have fixed it. Any idea what causes the issue, could it be field updates to airtable?
That’s usually the problem alright.
If it’s consistent we can take a look
