This week’s updates focused on making fields and option management more flexible, improving record editing workflows, and continuing to polish layouts and calendar behavior across Noloco.
More flexible badge styles for select fields
You can now choose between 2 visual styles for single and multi-select field badges.
This gives builders more control over how option fields look across records, layouts, and data views.
Improved field creation and editing
We rolled out another round of improvements to the field creation and editing experience.
Configuring fields should now feel cleaner, smoother, and easier to work through.
New and improved Duration field experience
Duration fields now include an improved picker experience along with a redesigned format selector.
This makes entering and formatting durations more intuitive for both builders and end users.
Inline option creation in data grids
You can now create new select-field options directly from select menus inside the data grid.
No more breaking your workflow just to add a missing option.
Safer field option deletion
We added confirmation prompts when deleting Noloco field options.
A small but important improvement to help prevent accidental destructive changes.
Polished grouped and card-based layouts
We shipped another round of UI refinements across redesigned views, including cleaner outlines, improved radius consistency, and more polished group and card headers.
Smarter import flow copy
Import flows now use clearer button labels when importing a single table.
A small usability improvement, but one that makes the flow easier to understand.
We’re excited to keep building alongside all of you ![]()
Your feedback and ideas continue to shape Noloco every single week - and will keep sharing weekly updates here so you always know what’s new ![]()
