This week’s updates focused on clearer publishing and billing workflows, stronger permission controls, and more capable AI-assisted building.
See what needs attention before publishing
The Publish button now highlights unpublished changes and surfaces build errors, making it easier to review what needs attention while your live app continues using the last published version.
Clearer AI credit plan changes
A dedicated checkout flow now clearly shows today’s charge, the credits added immediately, and future monthly billing.
For downgrades, the flow also makes clear that there is no charge today and that your existing credits remain available.
Build record-specific lists with Nola
Nola can now configure relative filters for lists, including multi-step relationships.
For example, you can ask Nola to create a list showing an employee’s related time-off requests, making it easier to build more contextual data views through conversation.
Safer permission-rule configuration
Permission rules now support object subfields and validate incomplete conditions before saving.
Broken rules are also flagged, and you’ll receive a warning before deleting a field that is used by a permission rule.
Improved formula results after schema changes
Formula recalculation now uses the current schema after fields are changed, disabled, or deleted.
This prevents outdated schema information from producing incorrect stored formula results.
Thanks for all the feedback and feature requests.
We’ll be back next week with another round of updates ![]()
